Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis
crwdns2869540:0crwdne2869540:0: 2.7K
3
26
97
2,681
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2959986:0crwdne2959986:0: 1
crwdns2959980:01crwdne2959980:0
crwdns2955944:0crwdne2955944:0: 5 - 10 crwdns2931279:0crwdne2931279:0
This guide will show the user of this scanner how to take apart the chassis so they can repair inside components.
    1. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove serial port connection: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove serial port connection: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove serial port connection: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Loosen the screws on the serial port by turning them counter clockwise by hand.
      • After loosening the screws, pull the serial port out.
    2. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove Lid: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove Lid: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove Lid: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift lid to its vertical position.
      • Pull lid straight up to remove it from the scanner.
    1. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Detach plastic latches: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Detach plastic latches: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Detach plastic latches: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
    2. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Continue latch detachment: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Continue latch detachment: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Continue latch detachment: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
      • Go all the way along the chassis until you can lift the upper lid.
    3. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Fully remove the upper lid: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Fully remove the upper lid: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Fully remove the upper lid: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
      • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
      • Grab the ribbon cable and gently pull it out of its slot with your fingers.
      • The upper lid can now safely be removed from the bottom lid.
Taylor Nesheim
crwdns2935283:010/11/11crwdne2935283:0
59 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-9, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 6-9, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S6G9
crwdns2935297:0132crwdne2935297:0
crwdns2936753:030crwdne2936753:0 97
crwdns2959996:0crwdne2959996:0 2,681
