Disassembling Microsoft Sculpt Comfort Bluetooth Mouse
crwdns2936621:0crwdne2936621:0
  1. Disassembling Microsoft Sculpt Comfort Bluetooth Mouse, Remove two pads on bottom to expose screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Thin blade/knife to start removal of bottom pads, then peel off. Lay flat to ensure it goes back on during assembly.
  2. Disassembling Microsoft Sculpt Comfort Bluetooth Mouse, Remove four T5 screws from bottom: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Microsoft Sculpt Comfort Bluetooth Mouse, Remove four T5 screws from bottom: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Four T5 screws open mouse. Two short at front, two long at rear.
  3. Disassembling Microsoft Sculpt Comfort Bluetooth Mouse, Remove Mouse Wheel Carefully: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When removing wheel, be careful as a a spring is underneath. Pry front holding wheel to ensure it does not pop, same with back.
  4. Disassembling Microsoft Sculpt Comfort Bluetooth Mouse, Clean debris from wheel and mouse: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Clean wheel and mouse - plenty of hairs as shown. Compressed duster spray helps.
  5. Disassembling Microsoft Sculpt Comfort Bluetooth Mouse, Optional disable left blue botton: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pop off Connector shown to disable blue button if you don't like that functionality
  6. Disassembling Microsoft Sculpt Comfort Bluetooth Mouse, Optional disable feedback device: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Connectors shown at rear of mouse can be disconnected to disable the feedback mechanism.
    • Several small phillips pan head screws will remove the sides and rear circuit board - keep flat head phillips in place for the laser assembly on the reverse side.
  7. Disassembling Microsoft Sculpt Comfort Bluetooth Mouse, Check contacts on battery mounts: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you had batteries corrode in your device, check your mounts. Ideally use a meter to see if you have continuity on the board.
deilert
crwdns2935283:002/19/14crwdne2935283:0
227 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 108
crwdns2942667:0crwdne2942667:0 1,298
