Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover
  1. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover, Motor Housing Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover, Motor Housing Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, gently pry off the aluminum drip ring.
  2. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a 4 mm pin punch and hammer, hammer the pin until it is dislodged from the planetary gear cover.
  3. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, pry the planetary gear cover from the mixer shaft.
  4. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a flathead screwdriver, remove the five 28 mm front motor housing screws.
    • Using the same flathead screwdriver, remove the two 28 mm locking screws.
    • One of the locking screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
  5. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn your device around. Using the same flathead screwdriver, remove the two 28 mm rear locking screws.
    • One of the rear motor housing screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
  6. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #2 screwdriver, remove the 10 mm screw from top of back cover.
    • The rear cover is now completely free from the mixer.
  7. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull the power cord from the notch in back of the mixer.
    • The motor housing cover is now completely free from the base of the mixer.
  8. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motor housing cover from the mixer base.
    • Be sure to place the cover upside-down to prevent grease from leaking out.
crwdns2935229:037crwdne2935229:0
Chris Gonzales
crwdns2935283:010/12/14crwdne2935283:0
1.632 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-28, Maness Fall 2014 crwdns2935289:0Cal Poly, Team 14-28, Maness Fall 2014crwdne2935289:0
CPSU-MANESS-F14S14G28
crwdns2935297:022crwdne2935297:0
crwdns2947412:027crwdne2947412:0
Well fine job! Just finished and t works!!!
James Anderson - crwdns2934203:0crwdne2934203:0
Instruccion is exelent but I veleave the problem is electric. can you give aidea. dhe machine does’nt work at all
Aristides Aleman - crwdns2934203:0crwdne2934203:0
Thank you! I'm repainting my white mixer a deep cherry red gloss to match my kitchen. These mixers can last 20+ years, if you take care of them. But, who wants the same color kitchen for that long? Bonus: saved $50+ by painting it the color I wanted, rather than pay the extra for a mixer from the colored choices.
Heather Schrader - crwdns2934203:0crwdne2934203:0
Do the motor housing sometimes become to hard to remove? I followed all the steps yet it still acts as if something inside the housing is keeping it from coming off.
Royce M - crwdns2934203:0crwdne2934203:0
Nothing else, only the planetary assembly, and the 9 big housing screws. Once those are off, it can take a lot of jiggling and persistence, mostly because there’s a vacuum between the vertical shaft and the bushing inside. Remember to loosen the cord in case to prevent yanking it accidentally when the cover comes off.
Ariel Cornejo -
crwdns2936751:024crwdne2936751:0 25
crwdns2936753:07crwdne2936753:0 198
crwdns2936753:030crwdne2936753:0 1,047
crwdns2942667:0crwdne2942667:0 114,274
