Disassembling Keurig Mini B-31 Arm
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Disassembling Keurig Mini B-31 Arm, Arm: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the needle removed, open the device by pulling up on the handle.
  2. Disassembling Keurig Mini B-31 Arm: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Keurig Mini B-31 Arm: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Keurig Mini B-31 Arm: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push in on one of the arms attached to the K-cup holder plastic housing to remove it from its rails. The arms are identical for both sides so once one side is free repeat the process for the second side.
    • The plastic is flexible and will not snap with the force applied.
    • Once the arms are removed, the configuration should look like the picture. The K-cup holder housing should be separated from the arms.
  3. Disassembling Keurig Mini B-31 Arm: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screw driver to remove the four 12 mm screws that hold the arm assembly in place.
  4. Disassembling Keurig Mini B-31 Arm: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Keurig Mini B-31 Arm: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the arm and pull up the handle assembly. It should easily come off.
    • This white tab falls off easily, remove it and set it aside to ensure it is not lost.
Andrew Adriance
crwdns2935283:001/14/14crwdne2935283:0
1,914 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-1, Forte Winter 2014 crwdns2935289:0Cal Poly, Team 17-1, Forte Winter 2014crwdne2935289:0
CPSU-FORTE-W14S17G1
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 106
