Disassembling KDDI Kyocera A5521K Logic Board
  1. Disassembling KDDI Kyocera A5521K Logic Board, Disassembling KDDI Kyocera A5521K Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling KDDI Kyocera A5521K Logic Board, Disassembling KDDI Kyocera A5521K Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling KDDI Kyocera A5521K Logic Board, Disassembling KDDI Kyocera A5521K Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the phone over to expose the battery cover.
    • Apply pressure to the back of the battery cover to slide it down.
    • The battery cover is now separate from the phone.
  2. Disassembling KDDI Kyocera A5521K Logic Board: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling KDDI Kyocera A5521K Logic Board: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling KDDI Kyocera A5521K Logic Board: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery by pushing it up and out from the bottom.
    • The battery, cover, and phone should now be separated.
  3. Disassembling KDDI Kyocera A5521K Logic Board, Back Plate: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling KDDI Kyocera A5521K Logic Board, Back Plate: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four screws with the Y0 screwdriver.
  4. Disassembling KDDI Kyocera A5521K Logic Board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling KDDI Kyocera A5521K Logic Board: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the black, rubber screw caps towards the top of the back of the phone to reveal two additional screws.
    • Remove the two screws with a Y0 screwdriver.
  5. Disassembling KDDI Kyocera A5521K Logic Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling KDDI Kyocera A5521K Logic Board: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling KDDI Kyocera A5521K Logic Board: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the phone 180 degrees.
    • Carefully separate the back plate from the remainder of the phone.
    • The back plate should now be detached from the rest of the phone.
  6. Disassembling KDDI Kyocera A5521K Logic Board, SD Card Slot: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling KDDI Kyocera A5521K Logic Board, SD Card Slot: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling KDDI Kyocera A5521K Logic Board, SD Card Slot: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the phone approximately 45 degrees to the right.
    • Gently pry up the SD card slot with a spudger.
  7. Disassembling KDDI Kyocera A5521K Logic Board, Logic Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling KDDI Kyocera A5521K Logic Board, Logic Board: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling KDDI Kyocera A5521K Logic Board, Logic Board: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up on the first connection shown using a pair of pliers.
    • Disconnect the first connection between the logic board and the wire using the pair of pliers.
  8. Disassembling KDDI Kyocera A5521K Logic Board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling KDDI Kyocera A5521K Logic Board: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling KDDI Kyocera A5521K Logic Board: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the above steps for the second connection.
    • Use the pliers to pry up the connection.
    • Use the pliers to disconnect the connection between the logic board and the wire.
  9. Disassembling KDDI Kyocera A5521K Logic Board: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up on the bottom of the logic board with a spudger.
    • Gently remove the rest of the logic board from the phone.
  10. Disassembling KDDI Kyocera A5521K Logic Board: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling KDDI Kyocera A5521K Logic Board: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The logic board should now be completely disconnected from the phone.
Dominic Grisafe
crwdns2935283:004/15/10crwdne2935283:0
157 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 28-25, Regan Spring 2010 crwdns2935289:0Cal Poly, Team 28-25, Regan Spring 2010crwdne2935289:0
CPSU-REGAN-S10S28G25
crwdns2935297:020crwdne2935297:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 1,877
