Disassembling JBL Charge Casing
    1. Disassembling JBL Charge Casing, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling JBL Charge Casing, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling JBL Charge Casing, Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Make sure the device is powered off before you begin to disassemble the speaker.
      • Remove the trim from the speaker using a jimmy or metal spudger.
    2. Disassembling JBL Charge Casing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling JBL Charge Casing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the PH1 screwdriver to remove all five of the 6 mm screws from the battery cover.
      • Remove the battery cover and set the cover aside.
    3. Disassembling JBL Charge Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling JBL Charge Casing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a spudger to carefully remove the liquid electrical tape that holds the battery inside the battery compartment.
      • Be careful not to puncture the battery, or damage the battery wire underneath the liquid electrical tape.
    4. Disassembling JBL Charge Casing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling JBL Charge Casing: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a spudger to lift the battery out of the device.
      • Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
      • Notice the wire that is connecting the battery to the device. Attempting to remove the battery completely could cause damage to the wire. Do not use a metal spudger to remove the battery, this could cause damage.
    5. Disassembling JBL Charge Casing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling JBL Charge Casing: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver.
    6. Disassembling JBL Charge Casing: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling JBL Charge Casing: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Starting in a corner of the device where the casing and the side meet, use a pointed metal spudger to pry the back casing off the speaker and the glue holding the seam together.
      • Slide the metal spudger along the seam to separate the back casing from the rest of the speaker.
    7. Disassembling JBL Charge Casing: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling JBL Charge Casing: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once the back casing is open, disconnect the three white connectors from the motherboard.
      • Remove the upper casing.
crwdns2935229:036crwdne2935229:0
Joe Durand
crwdns2935283:004/01/15crwdne2935283:0
2.313 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-4, Lancaster Spring 2015 crwdns2935289:0Cal Poly, Team 12-4, Lancaster Spring 2015crwdne2935289:0
CPSU-LANCASTER-S15S12G4
crwdns2935297:048crwdne2935297:0
crwdns2947412:011crwdne2947412:0
Breaking apart the halves takes patience. Took 30 minutes. Mine was glued together like a tank, and it was not easy at all to separate the halves. Maybe JBL saw this post and doubled the glue to dissuade DIY fixes. Once I separated the halves, it was easy, but be prepared to get moderately frustrated in doing so. Also, don't get angry and try to force them apart, because from my experience, I do believe there is a high risk potential of cracking either halve if attempting to brute force the issue. Remember, patience is a virtue here. Lastly, you can get a good set of spudger tools at Harbor Freight Tools for cheap. They are actually called Wax Carving tools made in India of stainless steel. Excellent set to complete this fix, and I can see that they will be very useful in the future if needed. 10/10 for the author for the breakdown instructions. Cheers!
Zabrot - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Follow these directions, Do not deviate from the path and you shall find Success awaits at journey's end.
rufusleehung - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
one essential moment. when you're trying to disasemble a cover there is also one bolt under the battery socket! it not shown on step 5!
freddyfresh90 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
It is told in step 4, but not shown. I looked up this guide when I was stuck after step 5 lol
Btw I am the editor as of Saturday, 27/August/2016. Mine had 4 PH2 screws around the outside and 1 ph2 under the battery. I am not sure if that is how it always was
ion418 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
smooth sailing until step 6. Finally gave up and trashed it out of frustration.
fredblue - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 87
crwdns2936753:030crwdne2936753:0 349
crwdns2942667:0crwdne2942667:0 92,934
