Disassembling IBM ThinkPad A30 Upper Case
    1. Disassembling IBM ThinkPad A30 Upper Case, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling IBM ThinkPad A30 Upper Case, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the ThinkPad over so that it is upside down.
      • Slide the highlighted tab to the left.
      • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
    1. Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the highlighted screw with a Phillips #1 screwdriver.
      • Pull the hard drive out.
    1. Disassembling IBM ThinkPad A30 Upper Case, Upper Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Make sure the laptop is upside down and oriented in the direction shown.
      • Remove the six 16.7mm screws inside the circled holes.
    2. Disassembling IBM ThinkPad A30 Upper Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Rotate the ThinkPad so that the hard drive bay is facing you.
      • Remove the black cover to reveal a 14.8mm screw.
      • Remove the uncovered screw with a Phillips #0 screwdriver.
    3. Disassembling IBM ThinkPad A30 Upper Case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling IBM ThinkPad A30 Upper Case: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the ThinkPad over and open the LCD panel.
      • Pry apart the keyboard with a plastic opening tool or with your fingers.
    4. Disassembling IBM ThinkPad A30 Upper Case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling IBM ThinkPad A30 Upper Case: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling IBM ThinkPad A30 Upper Case: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
      • Lift the front end of the keyboard as shown.
      • Using your fingers, remove the black film cover.
    5. Disassembling IBM ThinkPad A30 Upper Case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling IBM ThinkPad A30 Upper Case: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling IBM ThinkPad A30 Upper Case: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the connector attached to the motherboard.
      • Disconnect the ribbon cable by removing the connector.
    6. Disassembling IBM ThinkPad A30 Upper Case: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling IBM ThinkPad A30 Upper Case: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift and remove the keyboard.
      • Remove the two 5.6mm screws.
      • Remove the 16.7mm screw.
    7. Disassembling IBM ThinkPad A30 Upper Case: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling IBM ThinkPad A30 Upper Case: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling IBM ThinkPad A30 Upper Case: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • You will need to use a little force. Be wary of the tabs.
      • Pry off the upper case with your hands.
Alan
crwdns2935283:010/07/10crwdne2935283:0
380 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-44, Amido Fall 2010 crwdns2935289:0Cal Poly, Team 4-44, Amido Fall 2010crwdne2935289:0
CPSU-AMIDO-F10S4G44
crwdns2935297:0155crwdne2935297:0
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 93
crwdns2942667:0crwdne2942667:0 2,755
