IBM ThinkPad A30 Fan Replacement
    1. IBM ThinkPad A30 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM ThinkPad A30 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the ThinkPad over so that it is upside down.
      • Slide the highlighted tab to the left.
      • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
    1. IBM ThinkPad A30 Fan Replacement, Upper Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Make sure the laptop is upside down and oriented in the direction shown.
      • Remove the six 16.7mm screws inside the circled holes.
    2. IBM ThinkPad A30 Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Rotate the ThinkPad so that the hard drive bay is facing you.
      • Remove the black cover to reveal a 14.8mm screw.
      • Remove the uncovered screw with a Phillips #0 screwdriver.
    3. IBM ThinkPad A30 Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM ThinkPad A30 Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the ThinkPad over and open the LCD panel.
      • Pry apart the keyboard with a plastic opening tool or with your fingers.
    4. IBM ThinkPad A30 Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A30 Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A30 Fan Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
      • Lift the front end of the keyboard as shown.
      • Using your fingers, remove the black film cover.
    5. IBM ThinkPad A30 Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A30 Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A30 Fan Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the connector attached to the motherboard.
      • Disconnect the ribbon cable by removing the connector.
    6. IBM ThinkPad A30 Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM ThinkPad A30 Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift and remove the keyboard.
      • Remove the two 5.6mm screws.
      • Remove the 16.7mm screw.
    7. IBM ThinkPad A30 Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A30 Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A30 Fan Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • You will need to use a little force. Be wary of the tabs.
      • Pry off the upper case with your hands.
    1. IBM ThinkPad A30 Fan Replacement, Display Assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 5.6mm screw that holds the LCD to the upper case.
    2. IBM ThinkPad A30 Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A30 Fan Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A30 Fan Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the 5.6mm screw on the left side of the three-pronged connector.
      • Remove the other two 16.7mm screws.
      • Lift and remove connector.
    3. IBM ThinkPad A30 Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM ThinkPad A30 Fan Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull out the white tab connecting the LCD to the motherboard.
    4. IBM ThinkPad A30 Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IBM ThinkPad A30 Fan Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Turn the laptop so that the back is facing you.
      • Remove the four 5.6mm long screws.
    5. IBM ThinkPad A30 Fan Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A30 Fan Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A30 Fan Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Place the laptop so that the LCD is facing you again.
      • Gently lift the LCD monitor up and out.
      • Remove the black plastic tab.
    1. IBM ThinkPad A30 Fan Replacement, Fan: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the following screws from the fan retention bracket:
      • Single 5.6 mm screw.
      • Three 16.1 mm screws.
    2. IBM ThinkPad A30 Fan Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the heatsink bracket up.
    3. IBM ThinkPad A30 Fan Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A30 Fan Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 IBM ThinkPad A30 Fan Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Be careful not to pull too hard. There is a cable attached to the fan.
      • Lift the fan/heatsink assembly up.
      • Locate the fan power cable and pull upwards near the connector.
      • Remove the fan/heatsink assembly.
Jessica
crwdns2935283:010/06/10crwdne2935283:0
162 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-44, Amido Fall 2010 crwdns2935289:0Cal Poly, Team 4-44, Amido Fall 2010crwdne2935289:0
CPSU-AMIDO-F10S4G44
crwdns2935297:0155crwdne2935297:0
crwdns2936753:030crwdne2936753:0 71
crwdns2942667:0crwdne2942667:0 3,257
