Disassembling Honeywell HY-254-TGT Plastic Assembly
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Disassembling Honeywell HY-254-TGT Plastic Assembly, Plastic Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3/4" wing screws on the bottom of the fan by rotating them counter-clockwise.
  2. Disassembling Honeywell HY-254-TGT Plastic Assembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Honeywell HY-254-TGT Plastic Assembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Honeywell HY-254-TGT Plastic Assembly: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Twist the fan base counter-clockwise until the pins line up as shown.
    • Pull the base straight towards you to remove it, feeding the wire through the base.
  3. Disassembling Honeywell HY-254-TGT Plastic Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all of the marked 1/2" Phillips #02 screws on the backside of the fan
    • Remove the two marked 3/4" Phillips #02 screws in the middle.
  4. Disassembling Honeywell HY-254-TGT Plastic Assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Honeywell HY-254-TGT Plastic Assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Honeywell HY-254-TGT Plastic Assembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool or screwdriver to pry off the back of the fan, starting from the top down.
    • Be aware of two clips inside the fan, towards the bottom third of the fan. If the back appears stuck on certain spots, push inward edges of the front casing around the problematic area.
Daniel Anderson
crwdns2935283:010/01/15crwdne2935283:0
200 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 11-6, Forte Fall 2015 crwdns2935289:0Cal Poly, Team 11-6, Forte Fall 2015crwdne2935289:0
CPSU-FORTE-F15S11G6
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 125
