Disassembling HTC One V Back Case
crwdns2869540:0crwdne2869540:0: 3.9K
3
26
91
3,890
crwdns2959984:0crwdne2959984:0: 3
crwdns2959974:03crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 4
crwdns2959982:04crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:020crwdne2931287:0
If your back case is scratched or cracked, replacing your back case might be your best option. A new one can be installed using this guide.
    1. Disassembling HTC One V Back Case, Disassembling HTC ONE V Bottom Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling HTC One V Back Case, Disassembling HTC ONE V Bottom Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling HTC One V Back Case, Disassembling HTC ONE V Bottom Assembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Power off your device.
      • Remove the bottom cover by sliding it off.
    2. Disassembling HTC One V Back Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the SIM card.
      • Remove the four screws securing the bottom casing.
      • Two 3.0 mm Phillips #0 screws in the top left and right corners.
      • Two 2.0 mm Phillips #0 screws in the bottom left and right corners.
    3. Disassembling HTC One V Back Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling HTC One V Back Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the 2.0 mm Phillips #0 screws on either side of the phone.
    4. Disassembling HTC One V Back Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling HTC One V Back Case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling HTC One V Back Case: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a plastic opening tool to pry open the bottom casing.
      • Remove the bottom casing by pulling it towards you.
    1. Disassembling HTC One V Back Case, Disassembling HTC One V Back Case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling HTC One V Back Case, Disassembling HTC One V Back Case: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling HTC One V Back Case, Disassembling HTC One V Back Case: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the plastic opening tool to pry open the rear camera panel.
      • Remove both screws that are securing the back case.
      • One 4.0 mm Phillips #0 screw.
      • One 3.0 mm Phillips #0 screw.
    2. Disassembling HTC One V Back Case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling HTC One V Back Case: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling HTC One V Back Case: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a Jimmy to pry up the OEM SIM and SD card reader contact.
      • Pry from right to left to avoid potential damages to the ribbon.
    3. Disassembling HTC One V Back Case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling HTC One V Back Case: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling HTC One V Back Case: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using both thumbs, gently push on the two bottom rear corners of the motherboard.
      • Gently and slowly pull the screen out from the front of the phone, while feeding the OEM reader contact through the opening.
Michael Lucido
crwdns2935283:001/20/15crwdne2935283:0
852 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-3, Blackwell Winter 2015 crwdns2935289:0USF Tampa, Team 1-3, Blackwell Winter 2015crwdne2935289:0
USFT-BLACKWELL-W15S1G3
crwdns2935297:096crwdne2935297:0
crwdns2936753:030crwdne2936753:0 91
crwdns2959996:0crwdne2959996:0 3,890
