Disassembling HP Photosmart c3180 Top Panel
  1. Disassembling HP Photosmart c3180 Top Panel, Top Panel of HP Photosmart c3180 printer: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling HP Photosmart c3180 Top Panel, Top Panel of HP Photosmart c3180 printer: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before disassembling your printer, be sure that the printer has been unplugged to avoid any risk of injury.
    • Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
    • Remove the two T10 12mm Torx screws from the left side panel.
  2. Disassembling HP Photosmart c3180 Top Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling HP Photosmart c3180 Top Panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly pull the the back of the side panel until it separates from the body of the printer.
    • Rotate the side panel upwards while pulling it towards yourself to remove the panel.
  3. Disassembling HP Photosmart c3180 Top Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling HP Photosmart c3180 Top Panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the printer 90 degrees clockwise.
    • Grasp the paper tray and rotate it down.
    • Insert your fingers into the slot in the printer door and pull to rotate the gate down.
  4. Disassembling HP Photosmart c3180 Top Panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling HP Photosmart c3180 Top Panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two T10 12 mm Torx screws.
    • Grasp both sides of the side panel and pull it forward to remove the panel.
  5. Disassembling HP Photosmart c3180 Top Panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling HP Photosmart c3180 Top Panel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the printer 90 degrees counter clockwise.
    • Lift the scanner lid to expose the scanner glass.
  6. Disassembling HP Photosmart c3180 Top Panel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Do not attempt to lift the top panel off the printer yet because it is still connected to the printer body by a cable.
  7. Disassembling HP Photosmart c3180 Top Panel: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling HP Photosmart c3180 Top Panel: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
    • Remove the front panel by grasping its front and pulling away from the printer.
    Änderung des Textes: die kleine Lasche verriegelt die kleine Frontblende: mit leichtem Druck Richtung “rechte Druckerseite entriegeln, gleichzeitig jene Blende nach vorn lösen.
    Garofalo - crwdns2934203:0crwdne2934203:0
  8. Disassembling HP Photosmart c3180 Top Panel: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling HP Photosmart c3180 Top Panel: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cable connecting the top panel of the printer to the power button assembly.
  9. Disassembling HP Photosmart c3180 Top Panel: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the top panel of the printer away from the printer body.
    nur die dünne weiße Abdeckung, die graue bleibt noch; zuerst hinten anheben, vorn ist mittig eine Nase zu lösen.
crwdns2935229:011crwdne2935229:0
Jim
crwdns2935283:010/06/11crwdne2935283:0
1.623 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 20-30, Maness Fall 2011 crwdns2935289:0Cal Poly, Team 20-30, Maness Fall 2011crwdne2935289:0
CPSU-MANESS-F11S20G30
crwdns2935297:025crwdne2935297:0
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 6,921
