Disassembling HP Pavilion g7-2275dx Hard Drive
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Disassembling HP Pavilion g7-2275dx Hard Drive, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. Disassembling HP Pavilion g7-2275dx Hard Drive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery is held in by a latch in the front and tabs in the back.
    • Slide the lock switch left, towards the center of the computer.
    • Lift up the battery, rotating it up and away from you, then pull it out.
    • To put the battery back in, line it up with the battery bay and the holes for the tabs. Then let the battery rotate towards you and press down until the latch engages and you hear a click.
  3. Disassembling HP Pavilion g7-2275dx Hard Drive, Disassembling HP Pavilion g7-2275dx Back Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew one Phillips #1 screw from the back panel.
    • The screw is on a spring and attached to the panel. It will pop up, but will not separate from the back panel.
  4. Disassembling HP Pavilion g7-2275dx Hard Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling HP Pavilion g7-2275dx Hard Drive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the back panel down and pull it up.
  5. Disassembling HP Pavilion g7-2275dx Hard Drive, Hard Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling HP Pavilion g7-2275dx Hard Drive, Hard Drive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Static electricity can damage the components of your laptop. Make sure you are wearing an anti-static bracelet before you touch the hard drive.
    • Using the black tab on the connect and/or a prying tool, lift up to disconnect the black hard drive cable from the green circuit board.
    • Pull the black cable up and out of the back panel. This will make taking the hard drive out much easier.
  6. Disassembling HP Pavilion g7-2275dx Hard Drive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling HP Pavilion g7-2275dx Hard Drive: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull up on the plastic tab attached to the hard drive.
    • Pull the hard drive up and to the right to remove it completely from the laptop.
John Sutton
crwdns2935283:004/24/14crwdne2935283:0
1,572 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 11-51, Amido Spring 2014 crwdns2935289:0Cal Poly, Team 11-51, Amido Spring 2014crwdne2935289:0
CPSU-AMIDO-S14S11G51
crwdns2935297:021crwdne2935297:0
crwdns2942667:0crwdne2942667:0 112
