Disassembling Fujifilm Endeavor 100ix Outer Casing
  1. Disassembling Fujifilm Endeavor 100ix Outer Casing, Outer Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
  2. Disassembling Fujifilm Endeavor 100ix Outer Casing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the battery door.
  3. Disassembling Fujifilm Endeavor 100ix Outer Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the latch on the battery door marked by the word "BATT." Use your finger to pry it open.
  4. Disassembling Fujifilm Endeavor 100ix Outer Casing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the camera by pulling the battery door outwards.
  5. Disassembling Fujifilm Endeavor 100ix Outer Casing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate and remove three black 3.80mm screws on the back of the camera with the Phillips #00 screwdriver.
  6. Disassembling Fujifilm Endeavor 100ix Outer Casing: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Fujifilm Endeavor 100ix Outer Casing: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver.
  7. Disassembling Fujifilm Endeavor 100ix Outer Casing: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the film door latch located on the side of the camera.
    • Insert the spudger under the latch.
    • Caution: Be careful during the following step in order to not break any parts within the camera. Prying the latch in any other direction than perpendicular may result in broken parts.
    • Pry the latch upward, applying force perpendicular to the camera.
  8. Disassembling Fujifilm Endeavor 100ix Outer Casing: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the flat edge of the spudger between the gold front casing and the black back casing.
    • Pry the spudger upward until the black back casing snaps out and is dislodged on that edge of the camera.
  9. Disassembling Fujifilm Endeavor 100ix Outer Casing: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Squeeze the camera by placing a thumb on the tab marked CE.
    • Pull the back half of the camera firmly away from the camera body.
  10. Disassembling Fujifilm Endeavor 100ix Outer Casing: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate and remove the 3.80mm screw inside the film compartment with the Phillips #00 screwdriver.
  11. Disassembling Fujifilm Endeavor 100ix Outer Casing: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Fujifilm Endeavor 100ix Outer Casing: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the front cover off of the camera by lifting the tripod tab over the tripod hole.
Eric Nicolai
crwdns2935283:001/10/11crwdne2935283:0
679 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-5, Forte Winter 2011 crwdns2935289:0Cal Poly, Team 13-5, Forte Winter 2011crwdne2935289:0
CPSU-FORTE-W11S13G5
crwdns2935297:011crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,446
