Disassembling Forcite Helmet MK1S (Founders identical) Helmet Camera Module
  1. Disassembling Forcite Helmet MK1S (Founders identical) Helmet Camera Module, Helmet Camera Module: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Forcite Helmet MK1S camera module. Assuming you have disconnected the speakers, removed the lens with three screws from the outside and four screws (size 0 Phillips) securing the unit inside the helmet.
  2. Disassembling Forcite Helmet MK1S (Founders identical) Helmet Camera Module: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Front view of the module with camera clearly visible.
    • NOTE: Use soft cloths and avoid damaging camera.
    • The case is simple and made up of two parts front and back. Do not remove these screws yet.
  3. Disassembling Forcite Helmet MK1S (Founders identical) Helmet Camera Module: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Forcite Helmet MK1S (Founders identical) Helmet Camera Module: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Forcite Helmet MK1S (Founders identical) Helmet Camera Module: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently remove the rubber cover from the LED strip. This show's it removed by gently prying it free of the three tabs across the front.
    • Remove four (phillips 0) screws holding the LED stip.
    • Remove the LED strip leaving the exposed LEDs. Although this is now free of screws it is now held in place by the plug on the underside of the board. (see next step)
  4. Disassembling Forcite Helmet MK1S (Founders identical) Helmet Camera Module: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Forcite Helmet MK1S (Founders identical) Helmet Camera Module: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Forcite Helmet MK1S (Founders identical) Helmet Camera Module: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove this board gently pry it up working alternately from the screw holes either side of the centre. Each time lifting the board towards the centre. This will gently lift the socket off the plug powering the LEDs.
  5. Disassembling Forcite Helmet MK1S (Founders identical) Helmet Camera Module: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Forcite Helmet MK1S (Founders identical) Helmet Camera Module: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After the LED stip is removed
    • Remove the eight (Phillips 0) screws.
    • NOTE the top right screw is behind a warranty sticker.
    • Once the screws are removed, gently separate the front and back cases using a Pick or opening tool or similar.
    • CAREFUL when separating the cases, the battery module is loose once they separate and secured only by it's cables that you won't want to damage.
    • The second photo shows the back/inner case above the front/outer case still containing all parts for the module and the battery sitting loose.
  6. Disassembling Forcite Helmet MK1S (Founders identical) Helmet Camera Module: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Forcite Helmet MK1S (Founders identical) Helmet Camera Module: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Forcite Helmet MK1S (Founders identical) Helmet Camera Module: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The battery module (V-Shaped or butterfly shaped piece) sits loose and can be lifted a small distance out of the case.
    • Gently lift the yellow tape
    • Gently pry the plug from the main board.
  7. Disassembling Forcite Helmet MK1S (Founders identical) Helmet Camera Module: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Forcite Helmet MK1S (Founders identical) Helmet Camera Module: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Forcite Helmet MK1S (Founders identical) Helmet Camera Module: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The battery is a single V-Shaped module containing two separate batteries with a control board between them.
    • This is as far as my teardown goes and knowledge of battery replacement.
    • I am unable as of (April 2025) to get spare parts so I've swapped the battery module from my original Founders Helmet to the MK1S which lasted less than twelve months and about three days of riding.
    • From testing the module works fine on external power. Even operates correctly during a ride if plugged into a USB source. It appears to charge indefinitely correctly as well. As soon as external power is removed the helmet is dead without any power.
    • I appreciate contact with anyone knowing where or how to replace the battery module or other parts.
Stephen
crwdns2935283:008/18/12crwdne2935283:0
212 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 237
