Disassembling Flip Video Circuit Board
  1. Disassembling Flip Video Circuit Board, Outer Shell: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Flip Video Circuit Board, Outer Shell: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off the device and take the batteries out.
    • Remove metal sticker under the LCD screen with a spudger.
    • This may require a large force to pry off the glued sticker.
  2. Disassembling Flip Video Circuit Board: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
  3. Disassembling Flip Video Circuit Board: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Flip Video Circuit Board: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
  4. Disassembling Flip Video Circuit Board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open battery door. This can be done by gently depressing and sliding the battery down downward.
  5. Disassembling Flip Video Circuit Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger to separate outer shells.
    • The spudger must be inserted between the shell halves to pry the edges apart.
    • Slowly work around the outside to separate the halves.
  6. Disassembling Flip Video Circuit Board, Circuit Board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
  7. Disassembling Flip Video Circuit Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly lift the left side of the circuit board.
    • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
  8. Disassembling Flip Video Circuit Board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the USB port cable from the back side of the circuit board.
  9. Disassembling Flip Video Circuit Board: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide out the battery contacts.
    • Battery contacts
    • Slot where battery contacts were located
Elizabeth
crwdns2935283:004/15/10crwdne2935283:0
100 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 26-21, Regan Spring 2010 crwdns2935289:0Cal Poly, Team 26-21, Regan Spring 2010crwdne2935289:0
CPSU-REGAN-S10S26G21
Thank you. Where is the reset button on these first generation Flip Videos (mine doesn’t have one visible on outside, must be on inside.
sherrygray - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 2,299
