Disassembling Flat Iron Remington S-3500
  1. Disassembling Flat Iron Remington S-3500, What it looks like: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Flat Iron Remington S-3500, What it looks like: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • What the flat IRON looks like
  2. Disassembling Flat Iron Remington S-3500: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Flat Iron Remington S-3500: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate and remove the Hinge caps (One on each side)
    • On one side there will be a Philips screw below the cap
    • Take care. Screws seem quite soft, so find a well matching screwdriver
  3. Disassembling Flat Iron Remington S-3500: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Here you see the caps
    • Then the two "tube" like parts of the hinge/axle
    • Then comes the spring that forces the arms apart (Which came out just above where it is seen in the picture
  4. Disassembling Flat Iron Remington S-3500: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can now access the three screws holding back the covers in both sides.
  5. Disassembling Flat Iron Remington S-3500: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Notice the spring to the right, when you put it together again
  6. Disassembling Flat Iron Remington S-3500: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The swivel on the mains cord is held back by 2 screws also easily accessible when the arms are separated
    • I bend the small pickups in the white part a little bit to make then just a bit tighter. (I dont know if this was the loose connection, but after assembly the blue light signalling heating started working again)
    • Caution, the parts inside carry (in my case 230 Volts) So checking for loose connections while taken apart should be done with an Ohm Meter or similar.
Henrik Wahlberg
crwdns2935283:004/27/20crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 146
