Disassembling DualShock 4 Controller
crwdns2862623:0crwdne2862623:0
crwdns2948751:0crwdne2948751:0
    1. Disassembling DualShock 4 Controller, Controller: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
      • Be careful loosening the screws, using the wrong sized screwdriver, or letting the screwdriver slip can permanently damage the screw heads, making removal extremely difficult.
    2. Disassembling DualShock 4 Controller: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling DualShock 4 Controller: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling DualShock 4 Controller: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Four fragile plastic clips hold the casing together. You can see their locations more clearly in this guide.
      • The clips help hold the seams together. If you break these clips, the controller will still work.
      • Beginning with the left handle:
      • Pinch the left handle of the controller to introduce an opening.
      • Wedge a plastic opening tool into the opening and slide it up towards the joystick.
      • Pull down on tool to pry open the casing.
      • Repeat these steps for the right handle.
    3. Disassembling DualShock 4 Controller: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling DualShock 4 Controller: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling DualShock 4 Controller: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Wedge a plastic opening tool into the case-splittings and pull down to crack open the casing near the following buttons:
      • Share button
      • Options button
      • Split the plastic covers of the controller apart, taking note that they will still be attached by circuit board ribbons.
      • Three small pieces are often released from the framework. To prevent loss, maintain a controlled work field.
      • 2 Trigger Springs
      • 1 Grey Reset Button Extension
Mark
crwdns2935283:001/21/14crwdne2935283:0
8,106 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-21, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 6-21, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S6G21
crwdns2935297:086crwdne2935297:0
crwdns2942667:0crwdne2942667:0 2,698
