Disassembling DJI Mini 4 Pro
crwdns2937549:0crwdne2937549:0
To reassemble your device, follow these video instructions.
crwdns2935229:011crwdne2935229:0
Arty
crwdns2935283:010/27/19crwdne2935283:0
34,088 crwdns2915208:0crwdne2915208:0
crwdns2935297:0110crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Fantastic! My issue is losing connection even at 10 feet. I'm guessing the antenna is loose? Is there a guide to check the connections for the antenna?
Kevin - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
@kevin68196 test same remote on another drone first. Or try with another remote on your drone.
adrianTNT - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
@adriantnt I disassembled the drone and re attached the four arm connections. It worked great for 15 mins while flying and then lost signal again. Need to take it apart again.
Kevin Kaiser - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
@kevinkaise18799 I think some have hot glue on the antenna connectors to keep them in place, maybe that helps (if they popped out). Are the propellers OK? Maybe it causes excessive vibration. Just some ideas :)
@adriantnt I used hot glue but maybe it vibrated loose again. I should probably replace the propellers. They are original and are a little worn. Thanks!
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 112
crwdns2936753:030crwdne2936753:0 518
crwdns2942667:0crwdne2942667:0 10,779
