Disassembling Chef's Choice M115 Case
crwdns2869540:0crwdne2869540:0: 2.7천
2
24
105
2,693
crwdns2955950:0crwdne2955950:0: 2
crwdns2960008:02crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 4
crwdns2959974:04crwdne2959974:0
crwdns2955944:0crwdne2955944:0: 5 - 10 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
This is the most important step. You will not be able to proceed to any other guides until you successfully open the case. Be sure to layout your magnetic project mat to lay your screws as you remove them and be extra cautious of the sharp edges after you remove the case.
    1. Disassembling Chef's Choice M115 Case, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Chef's Choice M115 Case, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two rubber feet on the motor side of the device.
      • Remove the five Phillips screws from the bottom of the case.
      • These screws are recessed deep in the device, so a long, thin screwdriver is required.
    2. Disassembling Chef's Choice M115 Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two hex-cap screws on the bottom using a pair of pliers.
    3. Disassembling Chef's Choice M115 Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully flip the device right-side-up while grasping the top and bottom pieces.
      • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
    4. Disassembling Chef's Choice M115 Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the sharpener guard by gently pulling up on it.
      • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
Zachary Grounds
crwdns2935283:009/17/15crwdne2935283:0
592 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-3, Harley Fall 2015 crwdns2935289:0IUPUI, Team 3-3, Harley Fall 2015crwdne2935289:0
IUPUI-HARLEY-F15S3G3
Thank you for this information. Disassembly instructions for these units are not easy to find.
Robert Ford - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thank you. I have the M120 which I believe is similar. Only the three deeply recessed screws need to be removed to take the case apart. The others hold internal components in place.
John Slater - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 105
crwdns2959996:0crwdne2959996:0 2,693
