Disassembling Canon Selphy CP910 Body
  1. Disassembling Canon Selphy CP910 Body, Body: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Canon Selphy CP910 Body, Body: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the printer over.
    • Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
    • Keep track of these screws because you will need them to reassemble the printer.
  2. Disassembling Canon Selphy CP910 Body: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Canon Selphy CP910 Body: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Canon Selphy CP910 Body: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen up the four 10 mm corner screws.
    • A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
  3. Disassembling Canon Selphy CP910 Body: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Canon Selphy CP910 Body: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Canon Selphy CP910 Body: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the device around and remove the "open" lid.
    • This lid needs to be removed in order to take the printer apart.
    • Gently bend the lid and remove it from its hinges.
  4. Disassembling Canon Selphy CP910 Body: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Canon Selphy CP910 Body: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Canon Selphy CP910 Body: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the device back over and lift the top panel up.
    • Disconnect the ribbon cables leading to the LCD screen.
    • Pull the top panel off.
    Funktioniert auch mit Selphy CP520 aber mit PH2 Schraubenzieher in Schritt 1 und PH 00x2mm im Schritt 2
    trilex1 - crwdns2934203:0crwdne2934203:0
    The top panel is really tight, i must have broken the body since it is very tight, please be careful while open the top panel
    Alvin - crwdns2934203:0crwdne2934203:0
    Suite au blocage de la cartouche couleur !!!!
    J'ai du démonter : le coffret, carte électronique, et plaque métallique dessous en ôtant : les connections sur cartes et celui de la ventilation.
    - Opération réussie...
    puis dans l'ordre inverse : pour remonter. Assez facile mais avec minutie pour rebrancher les cartes vu la place minimum des connections.
    Joël vanhooren - crwdns2934203:0crwdne2934203:0
Christie Peralta
crwdns2935283:002/01/16crwdne2935283:0
727 crwdns2915208:0crwdne2915208:0
UW Tacoma, Team 1-6, Rose Winter 2016 crwdns2935289:0UW Tacoma, Team 1-6, Rose Winter 2016crwdne2935289:0
UWT-ROSE-W16S1G6
I read this recipe thinking that the 64 bit driver kit should contain all the necessary tools, but there is no way I can reach to the corner screws with it (step 2). It would be useful to have the narrow screwdriver also listed in the tools overview.
Matěj Korvas - crwdns2934203:0crwdne2934203:0
Be carefull!!! almost all this part is connected by ribbon and small plastic for tightened the cable and it is not a socket so you can only repair it for once or twice before the small blue plastic is separated from the cable and without the plastic the cable can not be plug to the board, and the gold plate is very frail could be broken easily!!! And the worst part is the cable which is tightened by switch at the backside of motherboard can be released accidentally such as in the delivery and make the photo print just a blank page, because mine now lcd and power button cable are broken and the worst part because don’t know about the cable, just ruined the head unit with the ink sheet and now photo print can’t be used anymore because it is dirty, IF YOU FEEL ANY PROBLEM WITH THIS SELPHY, DON’T EVER OPEN IT EVEN WITH PROFESSIONAL TECHNICIAN, JUST SELL IT!!
This “disassembly” is actually unfinished business…
1. I would like to point out, that for step 2 you really need a thin and long screw driver, otherwise you will have no luck with the corner screws, as stated above!
2. after step 4 there should follow taking out the motherboard, then removing the printing unit from the body, removing some more parts to finally clean the rolls and the printer head. That can solve the “white line” issues.
3. There’s a video on YT, not well done, but one gets the point on how to do it.
https://youtu.be/8-I-tVQJq-8
Nicolas Olonetzky - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 132
crwdns2942667:0crwdne2942667:0 11,814
