Disassembling Canon Powershot SD880 Logic Board
  1. Disassembling Canon Powershot SD880 Logic Board, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Canon Powershot SD880 Logic Board, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Canon Powershot SD880 Logic Board, Back Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Disassembling Canon Powershot SD880 Logic Board, Front Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Canon Powershot SD880 Logic Board, Front Cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Canon Powershot SD880 Logic Board, Front Cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Remove the 4.1 mm screw from the menu button side of the camera using a Phillips #00 screwdriver.
    • The two screws on the other side of the camera were already removed when the back cover was taken off.
  3. Disassembling Canon Powershot SD880 Logic Board, Top Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Canon Powershot SD880 Logic Board, Top Panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the green and white plugs that connect the top panel to the top of the logic board.
    • Dislodge the tab above the lens.
    • Dislodge the tab at the back.
  4. Disassembling Canon Powershot SD880 Logic Board, Logic Board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 2 screws(1.75mm) using a screwdriver.
    • Detach 3 ribbons by pulling up on them. All are on the front of the camera.
  5. Disassembling Canon Powershot SD880 Logic Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Canon Powershot SD880 Logic Board: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the newly exposed screw(1.75mm) with screwdriver.
    • Unhinge the black tab to slide out the ribbon.
    • The only thing keeping logic board in place is a black nub. Lift the logic board from that corner with increasing force until it pops out.
Juan Miguel
crwdns2935283:001/13/11crwdne2935283:0
104 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-3, Forte Winter 2011 crwdns2935289:0Cal Poly, Team 13-3, Forte Winter 2011crwdne2935289:0
CPSU-FORTE-W11S13G3
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 2,175
