Disassembling Canon PowerShot SD800 IS LCD Display
  1. Disassembling Canon PowerShot SD800 IS LCD Display, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one 2.25mm screw on the bottom.
  2. Disassembling Canon PowerShot SD800 IS LCD Display: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two 2.25mm screws on the right side looking from the front.
  3. Disassembling Canon PowerShot SD800 IS LCD Display: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one 4.7mm screw on the side with the AV output.
  4. Disassembling Canon PowerShot SD800 IS LCD Display: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull off the back cover.
    • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
  5. Disassembling Canon PowerShot SD800 IS LCD Display, LCD Assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 2 2.4mm screws on bottom.
  6. Disassembling Canon PowerShot SD800 IS LCD Display: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Follow the small data cable to where it connects to the camera.
    • Lift the back white portion to unlock the cable.
    • The cable should easily slide out.
    • The connector is very fragile. Use caution when lifting the lock.
  7. Disassembling Canon PowerShot SD800 IS LCD Display: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift LCD display off.
    • There will be two data cables still attached to the camera. Do not break them.
    • There may be a loose strip of metal along the inner side of the LCD display for a secure fit.
  8. Disassembling Canon PowerShot SD800 IS LCD Display: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Follow the larger cable to where it connects to the camera.
    • Lift the front black portion of the connector to unlock the data cable.
  9. Disassembling Canon PowerShot SD800 IS LCD Display, LCD Display: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the LCD display out from the four metal clamps.
  10. Disassembling Canon PowerShot SD800 IS LCD Display: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the LCD, peel the larger data cable off from the frame.
    • The LCD is glued by its data cable to the back of the LCD frame.
Jeremy Rabaino
crwdns2935283:010/10/10crwdne2935283:0
135 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 20-9, Maness Fall 2010 crwdns2935289:0Cal Poly, Team 20-9, Maness Fall 2010crwdne2935289:0
CPSU-MANESS-F10S20G9
crwdns2942667:0crwdne2942667:0 2,782
