Remove the back cover before removing LCD display.
            Remove one 2.25mm screw on the bottom.
            Remove two 2.25mm screws on the right side looking from the front.
            Remove one 4.7mm screw on the side with the AV output.
            Remove 2 2.4mm screws on bottom.
            Follow the small data cable to where it connects to the camera.
            Lift the back white portion to unlock the cable.
            The cable should easily slide out.
            Follow the larger cable to where it connects to the camera.
            Lift the front black portion of the connector to unlock the data cable.
            Pry the LCD display out from the four metal clamps.
            To remove the LCD, peel the larger data cable off from the frame.
