Disassembling Canon PowerShot SD700 Lens
  1. Disassembling Canon PowerShot SD700 Lens, Outside Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the camera by pressing the power button above the LCD screen.
  2. Disassembling Canon PowerShot SD700 Lens: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two small screws on the bottom of the camera using a Phillips #00 screwdriver.
  3. Disassembling Canon PowerShot SD700 Lens: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the two small screws on the right side of the camera.
  4. Disassembling Canon PowerShot SD700 Lens: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out digital label.
  5. Disassembling Canon PowerShot SD700 Lens: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the screw on the bottom of the camera near the battery and memory card slots.
    • This screw will be longer than the rest of the screws.
  6. Disassembling Canon PowerShot SD700 Lens: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front, back, and side casings from the camera and set to the side.
  7. Disassembling Canon PowerShot SD700 Lens, LCD screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws that connect the LCD and backlight to the main body of the camera.
  8. Disassembling Canon PowerShot SD700 Lens: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Canon PowerShot SD700 Lens: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Canon PowerShot SD700 Lens: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pry the LCD and the backlight from the main body of the camera.
    • Gently pry the LCD from the backlight.
    • The thin ribbon cable is for the backlight.
    • The thick ribbon cable is for the LCD screen.
  9. Disassembling Canon PowerShot SD700 Lens: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the ZIF connector that covers the thick ribbon cable.
    • This ZIF connector is fragile. Use caution when lifting it from its down position.
    • Insert the new LCD and reassemble the camera.
  10. Disassembling Canon PowerShot SD700 Lens, Backlight: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the ribbon from the housing on the circuitry.
    • Take the new ribbon and insert it into the housing.
    • Tweezers or a tool with a sharp point can be used.
  11. Disassembling Canon PowerShot SD700 Lens, Motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the LCD and backlight.
    • Remove the larger screw.
    • Remove the two smaller sized screws.
    • Remove the small screw.
  12. Disassembling Canon PowerShot SD700 Lens: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws near the the tripod mount using a Phillips #00 screwdriver.
  13. Disassembling Canon PowerShot SD700 Lens: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw next to the shutter on the top of the camera with a Phillips screwdriver.
  14. Disassembling Canon PowerShot SD700 Lens: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the orange ribbon cable by lifting the ZIF connector attached to the ribbon with a spudger.
  15. Disassembling Canon PowerShot SD700 Lens: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Canon PowerShot SD700 Lens: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the shutter along with the ribbon connected to it. This will remove the casing around the motherboard.
  16. Disassembling Canon PowerShot SD700 Lens: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Canon PowerShot SD700 Lens: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Canon PowerShot SD700 Lens: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the motherboard casing detached, remove the short orange ribbon by lifting the ZIF connector with a spudger or other plastic opening tools and slide the ribbon out. Detaching this ribbon will disconnect the side of the camera containing the motherboard from the rest of the camera.
  17. Disassembling Canon PowerShot SD700 Lens: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Canon PowerShot SD700 Lens: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the wires that are attached to the motherboard.
    • Remove the film by lifting it gently from the motherboard.
  18. Disassembling Canon PowerShot SD700 Lens: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the last wires connected to the motherboard by gently lifting upwards.
  19. Disassembling Canon PowerShot SD700 Lens: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Canon PowerShot SD700 Lens: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently lift the circuit board.
  20. Disassembling Canon PowerShot SD700 Lens: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Canon PowerShot SD700 Lens: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw using a Phillips #00 screwdriver.
    • Gently lift the motherboard away from the case.
  21. Disassembling Canon PowerShot SD700 Lens: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Canon PowerShot SD700 Lens: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw.
    • Once the screw is removed, you can remove the board.
  22. Disassembling Canon PowerShot SD700 Lens, Lens: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you have removed the lens from the main chassis, gently brush off any dirt, sand, or dust that may have accumulated in the crevices. Using a compressed air canister or a brush can help remove all the dirt.
Aaron Lee
crwdns2935283:004/07/11crwdne2935283:0
212 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-71, Walters Spring 2011 crwdns2935289:0Cal Poly, Team 9-71, Walters Spring 2011crwdne2935289:0
CPSU-WALTERS-S11S9G71
crwdns2942667:0crwdne2942667:0 5,165
