Disassembling Canon PowerShot SD1100 IS Camera Lens
  1. Disassembling Canon PowerShot SD1100 IS Camera Lens, Front and Rear Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Canon PowerShot SD1100 IS Camera Lens, Front and Rear Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove wrist strap and battery.
  2. Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The cases should now be removed.
  5. Disassembling Canon PowerShot SD1100 IS Camera Lens, LCD screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Canon PowerShot SD1100 IS Camera Lens, LCD screen: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the top-left screw above the LCD screen (0.100 in).
    • Remove the C-shaped plate from the side of the LCD screen.
  6. Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw from the top-right of the LCD screen (0.098 in).
    • Remove the L-shaped bar from the right of the LCD screen.
  7. Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to remove the L-shaped bar from the left-side of the LCD screen.
  8. Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to remove the connector ribbon from the top-left corner above the LCD screen.
    • Be gentle. This ribbon should stay attached to the screen.
  9. Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to lift the connector lock (black flap) at the end of the larger LCD connector ribbon on the front side of the camera.
    • Use the tweezers to lift this ribbon.
    • Use the tweezers to gently peel this ribbon from the one underneath it.
  10. Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The LCD screen should now be removed.
  11. Disassembling Canon PowerShot SD1100 IS Camera Lens, Flash Assembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw located on the side of the camera (0.072 in).
  12. Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to remove the lens ribbon from the circuit board.
    • Use the spudger to lift the ribbon.
    • This ribbon is connected to the lens, but the flash assembly ribbon is underneath it.
  13. Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the flash assembly ribbon.
    • The flash assembly ribbon is located underneath the lens assembly ribbon.
  14. Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the flash assembly, which includes the capacitor. If it resists, note the small hook on the right side near the bottom.
    • Be careful when taking out the capacitor. It could shock you.
  15. Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The capacitor should now be removed.
  16. Disassembling Canon PowerShot SD1100 IS Camera Lens, Camera Lens: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 4 screws from silver plate (0.106 in).
  17. Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use spudger to lift the second lens ribbon.
    • Remember the first ribbon was removed while taking out the flash assembly.
  18. Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use spudger to carefully lift the LED light off the upper-left corner of the lens.
  19. Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the lens.
  20. Disassembling Canon PowerShot SD1100 IS Camera Lens: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The camera lens should now be removed.
crwdns2935229:018crwdne2935229:0
Tyler Grossheim
crwdns2935283:001/25/11crwdne2935283:0
1,587 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-32, Regan Winter 2011 crwdns2935289:0Cal Poly, Team 3-32, Regan Winter 2011crwdne2935289:0
CPSU-REGAN-W11S3G32
crwdns2936753:030crwdne2936753:0 137
crwdns2942667:0crwdne2942667:0 21,987
