Disassembling BlackBerry Bold 9700 Motherboard Housing
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Disassembling BlackBerry Bold 9700 Motherboard Housing, Motherboard Housing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling BlackBerry Bold 9700 Motherboard Housing, Motherboard Housing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling BlackBerry Bold 9700 Motherboard Housing, Motherboard Housing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery by prying the bottom of the battery upward.
    • Once the battery is angled up, pull it away from the top of the device.
    • Be sure to remove all power sources before working on electronic devices to avoid harming yourself or the device.
  2. Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the SIM card from underneath the holding bracket upward toward the battery connector pins.
    • You must remove the SIM card before you can fully disassemble the device. Failure to do so may cause damage to components later on in this process.
  3. Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry off the AT&T logo panel with the plastic opening tool.
    • You will hear a snapping sound as the plastic tabs pop out.
  4. Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your T5 Torx screwdriver to remove the two black 5.57mm Torx head screws underneath the keyboard.
  5. Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to remove the frame of your device.
    • You will hear a snapping sound as the tabs pop out.
    • Once the case is loosened from the device, slide the case away from the top of the phone.
  6. Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the bottom of the keyboard upward.
    • Pull the keyboard away from the bottom of the LCD display and lift upward.
  7. Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two Torx head 4.13mm steel screws with your T5 Torx screwdriver.
  8. Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pry up the ribbon connector at the top of the phone with a plastic opening tool.
    • Ribbon connectors are fragile. Too much force in the wrong place will damage the ribbon and may force you to replace an entire assembly.
  9. Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the top two Torx head 4.13mm steel screws with your T5 Torx screwdriver.
    • You should now have two 5.57mm black torx head screws and four 4.13mm steel Torx head screws off to the side. Do not lose them.
    • Lift the clear plastic cover directly upward.
  10. Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling BlackBerry Bold 9700 Motherboard Housing: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the motherboard by the screen
    • Lift the board away from the base of the housing and vertically up.
Patrick
crwdns2935283:003/11/15crwdne2935283:0
649 crwdns2915208:0crwdne2915208:0
Colorado Springs, Team 9-3, Panko Spring 2015 crwdns2935289:0Colorado Springs, Team 9-3, Panko Spring 2015crwdne2935289:0
UCCS-PANKO-S15S9G3
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 91
