How to disassemble Axis 214 PTZ camera.
Remove (4) Phillips screws.
Carefully disconnect the ribbon connector.
If replacing the logic board, remove (2) cables at the connectors.
At the underside of the logic board, disconnect the connector.
Gently press back the plastic clip at both sides.
Remove 2 screws.
Remove (3) Phillip screws.
Carefully disconnect ribbon and flex cables.
Remove (2) Phillip screws.
Remove (1) protective clip.
Remove 2 screws one on each side.
Turn the latch mechanism to the right.
Remove (4) recessed screws.
Disconnect flat Ribbon Cable.
