Disassembling Asus Eee PC 1000HE Lower Assembly
  1. Disassembling Asus Eee PC 1000HE Lower Assembly, Lower Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the power and remove the battery before working on your Eee PC
    • Start by removing the keyboard
    • There are four latches on the top of the keyboard, use a paper clip or other object to disengage the latches
    • You may have to pull the keyboard up enough with the object - there is no spring mechanism to pop the keyboard out. One trick is after lifting it enough, to slide it (not too much) upward to remove the bottom side.
    • The keyboard assembly has also two plastic retention points on the sides, and some thermal tape sticking the keyboard down.
    • Caution: the keyboard has a ribbon connector underneath it which must be carefully unplugged before fully removing the keyboard.
  2. Disassembling Asus Eee PC 1000HE Lower Assembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Asus Eee PC 1000HE Lower Assembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 7 screws hold the front plate to the motherboard, as well as the ones on the rear of the PC.
    • Before taking off the case, you need to disconnect the touchpad and hotkeys cables.
adammw
crwdns2935283:001/21/11crwdne2935283:0
111 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 3,269
