Disassembling Antsle One D Server
  1. Disassembling Antsle One D Server, Remove Front Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Antsle One D Server, Remove Front Plate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Antsle One D Server, Remove Front Plate: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screws from the front panel.
    • There are also two screws in the front bottom of the plate that need to be removed.
    • When pulling the plate away from the body, be careful as a spring is keeping the silver button in place. The spring also easily slips off the button. Keep an eye out so you don't lose either of these items.
  2. Disassembling Antsle One D Server, Remove bottom plate: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Antsle One D Server, Remove bottom plate: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the bottom plate, remove the four-foot screws and the two screws from the rear plate, and the bottom will slide out.
  3. Disassembling Antsle One D Server, Remove Back Plate: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws from the rear plate
    • Unscrew the DC input connector
    • After, completing the previous step, and these six screws are removed, you can safely detach the rear plate.
  4. Disassembling Antsle One D Server, Remove Front Panel PCB: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws keeping the PCB mounted
    • Disconnect the power cable.
  5. Disassembling Antsle One D Server, Remove the hard drive bay: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Antsle One D Server, Remove the hard drive bay: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the power and SATA cables from the hard drives.
    • Remove the four screws keeping the hard drives in place.
  6. Disassembling Antsle One D Server, Remove the motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Antsle One D Server, Remove the motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four internal screws keeping the CPU pressed against the heat sink (labeled orange).
    • Remove the four outer screws (labeled yellow).
    • Lift the motherboard away. The thermal paste may have good adhesion and additional gentle force may be needed to pry it away.
    • Out of the box, the Antsle One D comes with 2 SATA hard drives. These can be disconnected from the SATA ports.
    • The front panel PCB is connected via a <look up> wire.
    • A power connector goes from the DC input to the motherboard.
    • A <look up> connector goes from the motherboard to the hard drive bay.
  7. Disassembling Antsle One D Server, CPU & RAM: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Antsle One D Server, CPU & RAM: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • CPU - Intel C3558 SR388 2.20GHZ
    • RAM - DDR4 2666 RDIMM 1.2v CL19
fausty
crwdns2935283:006/16/24crwdne2935283:0
302 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 12
