Disassembling ASUS K501U
  1. Disassembling ASUS K501U, ASUS K501U: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all shown screws from the bottom cover. These screws have different length. I color-coded screws with similar length in red, yellow and green. Make sure to install them correctly when you assemble the laptop back together.
    • Remove these top 4 screws.New line.
    • Remove these 2 side screws.
    • Remove these 4 bottom screws.
  2. Disassembling ASUS K501U: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the bottom cover from the palmrest assembly and remove it.
  3. Disassembling ASUS K501U: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four screws securing the battery.
    • The battery is connected to the motherboard via a cable.
  4. Disassembling ASUS K501U: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In order to unlock the battery connector you’ll have to slide the metal bracket to the shown direction.
  5. Disassembling ASUS K501U: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift up the battery cable from the connector.
    • Do not use metal objects to lift up the cable. You can short metal pins inside. It is reccomended that you use a plastic spudger.
  6. Disassembling ASUS K501U: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can find a new replacement battery using the part number printed on the original battery. I would recommend using a genuine Asus battery, not a third-party replacement. Replacement battery model B31N1429.
  7. Disassembling ASUS K501U: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Asus K501U motherboard has only one memory slot. Some memory is built into the motherboard. You can access the available slot if you remove the metal cover. You can install up to 8GB DDR3-12800 SODIMM RAM module into this slot.
  8. Disassembling ASUS K501U: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four screws from the hard drive caddy and remove the caddy. This laptop came with a m.2 solid state drive so there is no regular 2.5″ hard drive installed.
  9. Disassembling ASUS K501U: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one screw securing the solid state drive and pull the drive out. This is m.2 SATA III solid state drive (not NVMe).
  10. Disassembling ASUS K501U: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three screws securing the right fan.
    • Disconnect fan cable from the motherboard.
  11. Disassembling ASUS K501U: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the right fan.
  12. Disassembling ASUS K501U: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three screws securing the left fan.
  13. Disassembling ASUS K501U: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the left fan.
  14. Disassembling ASUS K501U: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The USB audio board is mounted under the right hinge.
    • Remove three screws from the right hinge. Remove one screw from the board.
    • Disconnect the USB audio board cable (color-coded in green).
    • Disconnect the right speaker cable (color-coded in yellow).
  15. Disassembling ASUS K501U: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unlock the connector first by lifting up the locking tab.
    • After that pull the cable out.
  16. Disassembling ASUS K501U: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the right hinge and remove the USB audio board.
  17. Disassembling ASUS K501U: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully disconnect wireless antenna cables from the wireless card.
  18. Disassembling ASUS K501U: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one screw securing the wireless card and pull it out.
tqd
crwdns2935283:004/09/25crwdne2935283:0
2,721 crwdns2915208:0crwdne2915208:0
crwdns2935297:018crwdne2935297:0
crwdns2936753:07crwdne2936753:0 51
crwdns2936753:030crwdne2936753:0 134
crwdns2942667:0crwdne2942667:0 218
