Disassembling APEX AP-GS918 Screen
crwdns2869540:0crwdne2869540:0: 1.3K
2
15
74
1,276
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2959986:0crwdne2959986:0: 1
crwdns2959980:01crwdne2959980:0
crwdns2955944:0crwdne2955944:0: 20 - 30 crwdns2931279:0crwdne2931279:0
If your screen has become damaged--cracked, scratched, or more--then it is in need of replacement. This guide will show you how to remove the battery and motherboard in order to access your broken screen.
    1. Disassembling APEX AP-GS918 Screen, Power/Volume Button: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling APEX AP-GS918 Screen, Power/Volume Button: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling APEX AP-GS918 Screen, Power/Volume Button: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
    2. Disassembling APEX AP-GS918 Screen: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling APEX AP-GS918 Screen: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling APEX AP-GS918 Screen: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
      • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
      • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
    3. Disassembling APEX AP-GS918 Screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling APEX AP-GS918 Screen: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
    1. Disassembling APEX AP-GS918 Screen, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling APEX AP-GS918 Screen, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Begin removing the black tape covering the motherboard inside the tablet.
    2. Disassembling APEX AP-GS918 Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • You will need to desolder the two contact points that connect the battery to the mother board.
      • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
      • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
      • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
    3. Disassembling APEX AP-GS918 Screen: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling APEX AP-GS918 Screen: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the black nylon spudger, get underneath the battery and begin prying it loose from the rest of the tablet.
      • The tape holding the battery to the tablet has a very strong hold so be prepared for resistance.
    1. Disassembling APEX AP-GS918 Screen, Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling APEX AP-GS918 Screen, Screen: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The motherboard will need to be removed in order to access the screen.
      • To remove the motherboard you must first unscrew four 4.9mm Phillips #00 screws.
    2. Disassembling APEX AP-GS918 Screen: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling APEX AP-GS918 Screen: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • To finish removing the motherboard you must release the two data cables holding the screen to it.
      • Use the black nylon spudger to lift the gray clips up 90° on the white connectors.
      • You can now remove the data cables from the slots and lift the motherboard out from the device.
    3. Disassembling APEX AP-GS918 Screen: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling APEX AP-GS918 Screen: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • After removing the motherboard, use the black nylon spudger to pop the screen out of the housing holding it to the front of the screen case.
    4. Disassembling APEX AP-GS918 Screen: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the thin plastic screen casing apart and you can remove the damaged screen.
Megan Lozicki
crwdns2935283:002/19/15crwdne2935283:0
416 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 9-1, Leahy Winter 2015 crwdns2935289:0USF Tampa, Team 9-1, Leahy Winter 2015crwdne2935289:0
USFT-LEAHY-W15S9G1
crwdns2936753:030crwdne2936753:0 74
crwdns2959996:0crwdne2959996:0 1,276
