Here's a guide showing how to remove the stereo out of your Honda Accord.
Note that I installed a head unit that required an aftermarket double-DIN adapter. The disassembly procedure may differ slightly for a Honda stock head unit.
Use a 10 mm wrench to disconnect the negative battery terminal, followed by the positive terminal.
Note that the dash has been taken apart before, namely to install all those fancy gizmos you see in this picture.
Use a #2 Philips screwdriver to remove the two screws holding the center of the dashboard in place.
crwdns2935267:0crwdne2935267:0Spudger$3.99
Gently insert a spudger or flathead screwdriver directly underneath the clock, just enough so you can pry out the clock. Perhaps a half inch or so will do it.
Slide the clock out to expose a sole Phillips screw.
Remove the screw using your Phillips #2 screwdriver.
Unplug the smaller connector first. There's a tab on top of the connector that you have to push downwards, then pull the connector. Make sure to grasp the connector itself, and not the wires.
Do the same with the larger connector. Again, there's a tab on top that needs to be pushed downward.
Now, gently pull the bottom of the center console towards you. Don't yank it out, there's two more connectors holding it in place.
First take off the red connector. Just like before, there's a tab on top of the connector that you have to push downwards first.
Follow suit with the green connector.
Center dash can now be fully removed.
Remove the four screws (two on each side) holding the double-DIN stereo frame in place using a #2 JIS screwdriver or 8mm socket wrench.
I stripped these screws, any idea how I can recover from that?
Update: Save yourself some trouble by using a 8mm socket wrench on these screws or purchase a #2 JIS screwdriver (Japanese Industrial Standards) to avoid cam-outs. I don't know why I didn't think of this sooner.
crwdns2935229:011crwdne2935229:0
Great article!!!
It’s easy understand and install myself
Also, I would like to introduce to you a great article for the double din head unit as well as questions around it: http://speedfinal.com/double-din-head-un...
Awesome detailed information step by step!!!
It’s helpful to install stereo system, I would like to share the double din head unit as well as buyer’s guide around it: https://consumercure.com/best-double-din...
Really appreciate your words and details that you mentioned. you have given good detaisl about the wiring of the streaeo system. I want to share an article about 6x9 speakers and buyers guide.
