Disassemble Proctor Silex® 2-Slice Extra Wide Slot Toaster Body
  1. Disassemble Proctor Silex® 2-Slice Extra Wide Slot Toaster Body, Disassemble Proctor Silex® 2-Slice Extra Wide Slot Toaster Body: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 1. Flip toaster over.
  2. Disassemble Proctor Silex® 2-Slice Extra Wide Slot Toaster Body: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 2. Locate four phillips screws on the bottom of the toaster.
  3. Disassemble Proctor Silex® 2-Slice Extra Wide Slot Toaster Body: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 3. Loosen and remove using a Phillips head screwdriver
  4. Disassemble Proctor Silex® 2-Slice Extra Wide Slot Toaster Body: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 4. Sides will pop out once screws are removed.
Carlos
crwdns2935283:007/23/13crwdne2935283:0
113 crwdns2915208:0crwdne2915208:0
UC Santa Barbara, Team 2-5, Bradley Summer 2013 crwdns2935289:0UC Santa Barbara, Team 2-5, Bradley Summer 2013crwdne2935289:0
UCSB-BRADLEY-R13S2G5
crwdns2931471:06crwdne2931471:0
Hi Carlos,
Before removing the cover I need to remove the PUSH LEVER.
Please forward instructions on HOW TO REMOVE THE PUSH LEVER.
Thank you.
Earle
earleb - crwdns2934203:0crwdne2934203:0
I Disassembled, cleaned and put it back together.  However the purpose of the exercise was to fix the browning feature or timing issue.  the little plastic bit that goes from the browning turn knob does not function.  So the push knob does not stay down.  This results in having to hold the push knob down till the toast is done to my satisfaction.  The little plastic bit does not connect properly to the PCB or whatever else it is connected to, and so the push knob on the side of the toaster does not stay down.. Allan
Allan Rodrigues - crwdns2934203:0crwdne2934203:0
To slide down the toast, the lever does not go down completely, leaving the top of bread exposed. Is there a way to adjust the depth the toast goes down? If so, could you send me instructions. Thank you
Christina - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,020
