crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0DirectPower DE157 Cordless drill-screwdrivercrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. DirectPower DE157 Cordless drill-screwdriver Teardown, DirectPower DE157 Cordless drill-screwdriver Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DirectPower DE157 Cordless drill-screwdriver Teardown, DirectPower DE157 Cordless drill-screwdriver Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The driver kit.
    • This is a more-or-less no-name cordless screwdriver/drill kit, but its construction more or less matches most of these devices.
  2. DirectPower DE157 Cordless drill-screwdriver Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DirectPower DE157 Cordless drill-screwdriver Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DirectPower DE157 Cordless drill-screwdriver Teardown: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The charger consist of a standard wallwart, output 14.4V 350mA, along with a little block (weighing nothing at all) to connect to one of the battery packs.
    • To open the charger block, unscrew three #1 Phillips screws.
  3. DirectPower DE157 Cordless drill-screwdriver Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DirectPower DE157 Cordless drill-screwdriver Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After lifting off the bottom, the PCB is exposed, and you can lift it out of the charger block along with the battery contacts. On the PCB we find:
    • A diode to protect against reverse current.
    • An LED and resistor that is on so long as the box gets power.
    • A giant 10 Ohm resistor to slightly current-limit the charge, and across which the green led and resistor are placed -- this will therefore light up as long as significant current passes to the battery.
  4. DirectPower DE157 Cordless drill-screwdriver Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DirectPower DE157 Cordless drill-screwdriver Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • One of the two battery packs. To open, remove
    • Four #1 Phillips screws.
  5. DirectPower DE157 Cordless drill-screwdriver Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DirectPower DE157 Cordless drill-screwdriver Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DirectPower DE157 Cordless drill-screwdriver Teardown: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the screws, turn right side up again and lift off the plastic cover, exposing 12 NiCd cells in a string, and nothing else.
    • Note that there is room on the right side for three more cells, which would make a 18V battery pack.
    • Especially cheaper makers usually have versions for 7.2V/9.6V/12/14.4/18V all using the same plastic, just more or less cells and a different motor.
Jasper
crwdns2935283:005/02/10crwdne2935283:0
136 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 2,559
