Digital2 Platinum Pad 9 Volume Buttons Replacement
  1. Digital2 Platinum Pad 9 Volume Buttons Replacement, External Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 Volume Buttons Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Digital2 Platinum Pad 9 Volume Buttons Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 Volume Buttons Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Digital2 Platinum Pad 9 Volume Buttons Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
  4. Digital2 Platinum Pad 9 Volume Buttons Replacement, Volume Buttons: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can locate the volume buttons on one of the longer sides of the tablet.
  5. Digital2 Platinum Pad 9 Volume Buttons Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the ZIF connector that is attached to the volume buttons ribbon cable.
  6. Digital2 Platinum Pad 9 Volume Buttons Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Then remove the ribbon cable from the ZIF connector.
  7. Digital2 Platinum Pad 9 Volume Buttons Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure to separate the volume button's cable from the cable connecting the motherboard to the screen
  8. Digital2 Platinum Pad 9 Volume Buttons Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Digital2 Platinum Pad 9 Volume Buttons Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Then use the precision tweezers to grab the volume buttons.
    • Pull until the buttons come out.
David DeMeritt
crwdns2935283:003/08/16crwdne2935283:0
637 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-6, Landers Spring 2016 crwdns2935289:0UMass Dartmouth, Team 5-6, Landers Spring 2016crwdne2935289:0
UMASSD-LANDERS-S16S5G6
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 158
