Digital2 D2-861G Camera Replacement
  1. Digital2 D2-861G Camera Replacement, Camera: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Working on your device while powered on may result in electric shock. Make sure to unplug and power down your device before you begin.
    • Place your device on a soft cloth to avoid scratching the screen
    • Flip your device over so back panel is facing upwards.
  2. Digital2 D2-861G Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Do not use a lot of force as it can break the clips or the back panel.
    • Insert spudger in the slot below the micro SD card.
    • You should hear clips releasing as you pry along the edges.
    • With the spudger tool, run along the edges of the backing undoing 20 plastic clips.
  3. Digital2 D2-861G Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnecting the bundled cable connector helps avoid short circuiting anything on the device.
    • Locate the bundled cable connector and disconnect it by simply pulling it gently or using a spudger.
  4. Digital2 D2-861G Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Digital2 D2-861G Camera Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate and unplug the flat-top connector from the motherboard..
    • To unplug the connector go under it with either side of the spudger and lift up.
  5. Digital2 D2-861G Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Digital2 D2-861G Camera Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Avoid pulling the gold connector as it can be damaged and/or broken.
    • To remove the camera, simply use the pointed end of the spudger and insert it in the corner and gently lift.
Eduardo Duran
crwdns2935283:009/29/16crwdne2935283:0
600 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-3, Crane Fall 2016 crwdns2935289:0Eastern Washington University, Team 1-3, Crane Fall 2016crwdne2935289:0
EWU-CRANE-F16S1G3
crwdns2942667:0crwdne2942667:0 204
