This guide will be showing you how to replace the 3.7V battery in the back of the tablet. Be sure to carefully remove the battery from the back of the screen and do not puncture it.
Battery information:
- JZ Li-ion PL28106110
+ 3.7V 3100MAH 1406
Flip your device over so back panel is facing upwards
Insert spudger in the slot below the micro SD card
With the spudger tool, run along the edges of the backing undoing 20 plastic clips.
Remove ALL the yellow tape securing the gold colored ZIF (Zero insertion force) connector and the battery. Discard or save the tape if you would like.
To unclip the connector. Go under the black tab with a spudger or finger nail and simply lift up.
Locate the bundled cable connector and disconnect it by simply pulling it gently with your hands or using a spudger.
Use prying tools to carefully break the adhesive under the battery
crwdns2917034:0crwdne2917034:0
where do you find the replacement battery?
