Digiland DL1168A Front/Rear Camera Replacement
  1. Digiland DL1168A Front/Rear Camera Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  2. Digiland DL1168A Front/Rear Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Digiland DL1168A Front/Rear Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift back panel away from the body of the device.
    • Be gentle when lifting the back panel. The speaker wires are still connected to both the front and back panel.
  3. Digiland DL1168A Front/Rear Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Digiland DL1168A Front/Rear Camera Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder the four wires connecting the rear case to the motherboard.
    • Disconnect the wires from the motherboard.
    • Remove the rear case from the device.
  4. Digiland DL1168A Front/Rear Camera Replacement, Front/Rear Camera: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to gently insert between the front and back panels of the device. Carefully slide the tool around the perimeter to release the clips securing the back panel. Continue until the back panel can be lifted away without resistance.
  5. Digiland DL1168A Front/Rear Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the back panel from the device.
    • Warning: Do not fully separate the back panel. The speaker wires are still connected to the motherboard.
  6. Digiland DL1168A Front/Rear Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a soldering iron to desolder the four wires connecting the rear case speaker to the motherboard. After desoldering, set the back panel aside.
    • Use a pair of tweezers to carefully remove the plastic cover holding the camera lens in place. Avoid applying too much pressure to prevent damaging nearby components.
    • Use tweezers to slowly lift the rear portion of the camera. Caution: The camera is connected to the back casing with a small ribbon cable. Lift gently to avoid tearing it.
To reassemble your device, follow these instructions in reverse order. Make sure to resolder the speaker wires correctly before closing the case.
Payton Boshears
crwdns2935283:010/15/19crwdne2935283:0
97 crwdns2915208:0crwdne2915208:0
Grand Valley State University, Team S1-G1, DeVasto Fall 2019 crwdns2935289:0Grand Valley State University, Team S1-G1, DeVasto Fall 2019crwdne2935289:0
GVSU-DEVASTO-F19S1G1
crwdns2942667:0crwdne2942667:0 161
