Digiland 10.1'' DL1016 Screen Replacement
Virginia Tapia
crwdns2944107:0crwdnd2944107:0Virginia Tapiacrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0N'w 31, 2019crwdne2944111:0
crwdns2931287:030crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
use this guide if your display is faulty, will not turn on, or either damaged in any way than this guide will help you replace the screen properly and carefully for your Digiland "10.1" DL1016 tablet
crwdns2944105:0crwdne2944105:0
  1. Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Remove Backing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Remove Backing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening pick and an opening tool to pry the backing off the back of the tablet.
    • You may need some force when doing this and if needed use a metal spudger.
  2. Digiland 10.1'' DL1016 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Digiland 10.1'' DL1016 Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the backing off.
  3. Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Disconnect Wires going off the Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Disconnect Wires going off the Motherboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the wiring back.
    • You may need to use a metal spudger to lift the wire connector off the back of the screen.
  4. Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Remove Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Remove Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an ESD safe pryer to lift the battery up.
    • There is glue that holds the battery down, so carefully pry it open. You may need to use some force.
  5. Digiland 10.1'' DL1016 Screen Replacement, Power Button: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the black cable off the motherboard.
    • Remove the four 1.5mm Phillips #000 screws from the motherboard.
  6. Digiland 10.1'' DL1016 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Digiland 10.1'' DL1016 Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure the ribbon cables are free or unconnected so the motherboard is able to be moved.
    • Use a metal spudger to slide underneath the motherboard and push it up so it's unstuck from the tablet.
    • Lift up the motherboard and place it somewhere that is clean and kept safe.
  7. Digiland 10.1'' DL1016 Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Digiland 10.1'' DL1016 Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the tape from the backside of the tablet along with the wiring.
    • Make space so you can pry the motherboard away from the digitizer.
  8. Digiland 10.1'' DL1016 Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Digiland 10.1'' DL1016 Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the motherboard is pulled away, the screen should be free of all other components.
    • Check around the edges so that no tape is stuck to the edges or wiring and just push off digitizer and replace screen if needed.
Virginia Tapia
crwdns2935283:008/26/19crwdne2935283:0
389 crwdns2915208:0crwdne2915208:0
Gateway, Team S1-G2, Saknee Fall 2019 crwdns2935289:0Gateway, Team S1-G2, Saknee Fall 2019crwdne2935289:0
GCC-SAKNEE-F19S1G2
Where can i get the screen for this tablet? i need to order online and currently i am in india.
Arivu Alagan - crwdns2934203:0crwdne2934203:0
Where will I get screen in kenya
Josphat Mutai - crwdns2934203:0crwdne2934203:0
My phone crack,I need screen only
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 1,951
