Digiland 10.1'' DL1016 Battery Replacement
  1. Digiland 10.1'' DL1016 Battery Replacement, Digiland 10.1'' DL1016 Remove Backing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Digiland 10.1'' DL1016 Battery Replacement, Digiland 10.1'' DL1016 Remove Backing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening pick and an opening tool to pry the backing off the back of the tablet.
    • You may need some force when doing this and if needed use a metal spudger.
  2. Digiland 10.1'' DL1016 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Digiland 10.1'' DL1016 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the backing off.
  3. Digiland 10.1'' DL1016 Battery Replacement, Digiland 10.1'' DL1016 Disconnect LCD Connectors: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Digiland 10.1'' DL1016 Battery Replacement, Digiland 10.1'' DL1016 Disconnect LCD Connectors: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Digiland 10.1'' DL1016 Battery Replacement, Digiland 10.1'' DL1016 Disconnect LCD Connectors: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull back the black flaps on the ZIF cable connectors.
    • Pull the ribbon cables out of the connectors.
  4. Digiland 10.1'' DL1016 Battery Replacement, Digiland 10.1'' DL1016 Remove Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Digiland 10.1'' DL1016 Battery Replacement, Digiland 10.1'' DL1016 Remove Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an ESD safe pryer to lift the battery up.
    • There is glue that holds the battery down, so carefully pry it open. You may need to use some force.
  5. Digiland 10.1'' DL1016 Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you remove the battery, simply replace the battery with a new one.
Virginia Tapia
crwdns2935283:008/26/19crwdne2935283:0
395 crwdns2915208:0crwdne2915208:0
Gateway, Team S1-G2, Saknee Fall 2019 crwdns2935289:0Gateway, Team S1-G2, Saknee Fall 2019crwdne2935289:0
GCC-SAKNEE-F19S1G2
Where I can buy this battery ? From the screenshot it looks to be a fit for a Tanoshi 2 in 1 computer
Sergii Prokhorov - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,457
