crwdns2959928:0crwdne2959928:0 ↓If you need to replace your motherboard or inspect its solder connections, use this guide to remove it. Removing the motherboard will be necessary if you want to replace any other component of the device.
Remove the four 8mm Phillips #0 screws located on the back panel.
Remove the back panel to expose the motherboard.
Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
My digitech rp 80 not work. How to get new motherboard
Thadevus - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My digitecj rp 80 not working. No display no sound how to get new motherboard
Does anyone know where I can get the tone library push button/knob assy? Mine broke off.
Michael Adkins - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Quiero comprar una estoy en Ecuador. Quiero comprar la moterboard
Lenin Omar Guerra Chango - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
