DigiLand DL801W Microphone Replacement
  1. DigiLand DL801W Microphone Replacement, Microphone: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Please be aware that removing the back panel from the tablet could cause damage to the back or front panel.
    • Before opening your DigiLand Tablet, ensure that the MicroSD card is removed.
    • Hold the tablet in one hand (not your primary hand) so that the bottom edge of the tablet is facing you and the back of the tablet is facing up.
    • Using a blue plastic opening tool, gently insert the tool between the back panel and the main body.
    • Going around the edge of the tablet, gently pry open the back panel. As you go around, you will hear a click.
  2. DigiLand DL801W Microphone Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the black spudger, insert the point underneath the red and black wires. Gently lift the microphone out of its socket.
    • Where the red and black wires connect to the motherboard, use a soldering iron to remove the defective microphone.
    • If you have removed the microphone and cannot remember which wire went where, don't worry. The wire terminals on the motherboard are marked with a " + " and " - " sign.
Travis Mangum
crwdns2935283:009/17/15crwdne2935283:0
572 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-4, Harley Fall 2015 crwdns2935289:0IUPUI, Team 3-4, Harley Fall 2015crwdne2935289:0
IUPUI-HARLEY-F15S3G4
crwdns2942667:0crwdne2942667:0 445
