DigiLand DL1010Q Battery Replacement
  1. DigiLand DL1010Q Battery Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a J00 Philips head screwdriver, unscrew the two 4mm black screws located at the bottom of the device.
    • Before disassembling your device, be sure it is powered off.
  2. DigiLand DL1010Q Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DigiLand DL1010Q Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  3. DigiLand DL1010Q Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift back panel away from the body of the device.
    • Speaker wires are connected to both the front and back panel.
  4. DigiLand DL1010Q Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DigiLand DL1010Q Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder positive and negative, red and black, wires from the mother board that are connected to the battery.
    • The soldering tool is hot, and will burn. For how to use a soldering tool follow the How to Solder Guide
  5. DigiLand DL1010Q Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DigiLand DL1010Q Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a metal spudger tool, wedge between battery and metal screen.
    • Follow the edge of the battery to loosen the glue.
  6. DigiLand DL1010Q Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DigiLand DL1010Q Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the glue is loosened, you should be able to pry off the battery from the screen.
    • Using your hands, pull up on the battery to pull battery off.
    • Pulling on the battery causes you to bend the battery. Bending the battery could cause it to break open. Battery fumes are toxic and unsafe.
    • The battery will be completely disconnected and you can set the battery aside in a safe place.
Faith Lebo
crwdns2935283:009/28/15crwdne2935283:0
192 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-5, Matresse Fall 2015 crwdns2935289:0Eastern Washington University, Team 1-5, Matresse Fall 2015crwdne2935289:0
EWU-MATRESSE-F15S1G5
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 4,645
