Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement
  1. Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement, Unplug: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you start, remember to disconnect the outlet from the mains.
  2. Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seal on the back of the device.
  3. Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the first screw of the pad.
    • Then unscrew the four remaining screws and pull up to remove it.
    • Finally, remove the screws located on the hull of the device.
    • This step is the same for both carbons.
    • Trap the two carbons to be able to take out the rotor. With a screwdriver to lift them up, then with another screwdriver press the tab.
    • Lift the carbons and with the other tip of the screwdriver, come twist the small paw.
    • Then remove the carbon.
    • Remove the rotor by lifting the frame to be able to retrieve it more easily.
  4. Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a soldering iron to weld the component's rotor.
    • De-solder at the location of the wires.
    • Then remove the wires one by one to remove the component.
  5. Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Return the new component to its location.
    • Then unfold the four threads in their place.
  6. Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Replace the rotor in its housing.
    • Unlock the carbons.
    • Replace the cable, the sheath must arrive between the two studs and the sleeve must be positioned in its housing.
  7. Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Replace the hull of the sander by being careful to properly position the stabilisers in their housing.
  8. Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dexter Wired Multifunction Sander 220W - 220MFS2.5 Engine Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Replace the pad by positioning it perfectly in the tips.
    • Screw the four screws.
    • Then the last screw. Finally, put the joint back in its place.
To reassemble follow the steps in reverse.
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934883:0HelloMacOScrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Céline Chemineau
crwdns2935283:001/29/20crwdne2935283:0
16.728 crwdns2915208:0crwdne2915208:0
crwdns2935297:095crwdne2935297:0
Leroy Merlin crwdns2935289:0Leroy Merlincrwdne2935289:0
Community
crwdns2931471:038crwdne2931471:0
crwdns2935297:0244crwdne2935297:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 141
