By the end of the guide you will have replaced your output shaft.
Open the chuck to the maximum to gain access to the inner screw.
Lock the chuck using a 15 spanner (thickness 3), then unscrew to the right with a pz3 screwdriver.
Using a pair of pliers, unscrew the chuck.
Using a screwdriver or screwdriver, unscrew and open the device.
Using a screwdriver, lift the spring of the two brushes.
Tighten the screws to close the device.
Screw the chuck back on by hand.
Then using a screwdriver replace the screw, and screw to the left.
in order to reassemble preform the steps in reverse order.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934883:0HelloMacOScrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
