Remove the dust case and the seal on the back of the device.
Unscrew the six screws from the pad.
Lock the motor with a screwdriver to be able to unscrew the centre screw, you will not be able to get there without blocking the gear.
Using a screwdriver or screwdriver, unscrew and open the device.
Unscrew the two screws from the domino to pull out the brown and blue cables.
Reconnect the new cable to the domino.
Then replace the cable, the sheath must arrive between the two pads and the sleeve must be positioned in its housing.
Replace the shell, then screw it back on.
Reposition the part, then lock the engine with a screwdriver to screw.
Put the tray back on and screw the screws.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934883:0HelloMacOScrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
