This tutorial shows you the change of only one carbon, to change the second you just have to follow the same method.
Remove the three screws from the pad.
Be careful to keep the three small marbles.
Unscrew the screws to open the shell.
Using a screwdriver lift the brushes.
Remove the carbon from its housing then take it out.
Using pliers, fold down the small tab.
Replace the new carbon in its carbon holder.
Reconnect the carbon, test if the carbon slides well inside.
Replace the retaining flange, be careful to have the three small balls.
Tighten the three screws of the retaining plate then that of the pad.
To reassemble follow guide through or in reverse
crwdns2934873:0crwdne2934873:0
100%
crwdns2934883:0HelloMacOScrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
