Unscrew the 6 Torx T5 screws from the back of the device
Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
Screen Information: Model AM0310R-04 Lot # NHT18080052
Using a spudger, unplug the Charging Port connector from the motherboard.
Remove the 2 silver Torx T5 screws holding the charging port down.
Remove the Charging Port Assembly from the motherboard.
Remove the silver Torx T5 screw holding the motherboard down.
Using a spudger, carefully remove the battery connector on the left side of the motherboard.
Using a spudger, carefully pry up the motherboard to remove it.
Using a spudger, carefully pry up and remove the speaker at the top.
Put down new adhesive tape(be careful not to let it get in the way of the speaker).
