Dexcom G6 Receiver Motherboard Replacement
  1. Dexcom G6 Receiver Motherboard Replacement, Display and Front Bezel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 6 Torx T5 screws from the back of the device
  2. Dexcom G6 Receiver Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dexcom G6 Receiver Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
    • Screen Information: Model AM0310R-04 Lot # NHT18080052
    Thank you! Where can we buy the screen?
    Enrique - crwdns2934203:0crwdne2934203:0
    I didn't get any of the details on the screen when I tore it down, I will try to get the information from the original display when I can.
    Andrew S -
    Have you found any info on getting a replacement Screen? Some company must make theses
    Jim Beamed - crwdns2934203:0crwdne2934203:0
    Yes, this would be great to know. I can't afford to replace this a 4th for my Daughter, but I while heartedly believe in right to repair!!
    Rafael Rasillo -
    I'm not sure if you can find the displays anywhere. The only number (presumably model number) I could find on the screen was AM0310R-04 and the Lot Number NHT18080052.
    Andrew S -
  3. Dexcom G6 Receiver Motherboard Replacement, Charging Port: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, unplug the Charging Port connector from the motherboard.
  4. Dexcom G6 Receiver Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2 silver Torx T5 screws holding the charging port down.
  5. Dexcom G6 Receiver Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Charging Port Assembly from the motherboard.
  6. Dexcom G6 Receiver Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the silver Torx T5 screw holding the motherboard down.
  7. Dexcom G6 Receiver Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dexcom G6 Receiver Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, carefully remove the battery connector on the left side of the motherboard.
  8. Dexcom G6 Receiver Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, carefully pry up the motherboard to remove it.
Andrew S
crwdns2935283:007/30/21crwdne2935283:0
15,331 crwdns2915208:0crwdne2915208:0
do you know of anyone that can fix these items
Rick MacDonald - crwdns2934203:0crwdne2934203:0
anyone out there fix these items
crwdns2942667:0crwdne2942667:0 951
