This guide will show you how to disconnect the display and display frame from the motherboard.
Unscrew the 6 Torx T5 screws from the back of the device
Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
Screen Information: Model AM0310R-04 Lot # NHT18080052
crwdns2947412:07crwdne2947412:0
Where can the replacement parts be found? And a charging port?
Also looking 2 the display. Have 2 dexcom receivers here and both with broken displays.
I'm not sure if you can find the displays anywhere. The only number (presumably model number) I could find on the screen was AM0310R-04 and the Lot Number NHT18080052.
Andrew S -
Sharewith us where we can find the displays to buy
I need assistance on a little project I’m working on requiring the display out of the dexcom receiver
